Demander by Innocent159
Is it normal to get min 137fps on fraps and max 179fps
Settings is high @ 1980x1080. 1080p?
Depends what you are playing/what exact settings
theres games where you will get 15fps and games where you will get 5000fps, so i need to know what game/benchmark did you play first
The single player isn't worth benching, its not at all intensive. Play multiplayer on a big server and report back. I know what my rig gets with it (AMD 280x with an AMD 8320).
Thanks. Just asking because I was thinking impossible. But doesn't lag happen because of your internet connection?
Latency not fps unless I guess if the server is a potato (I have no idea about server fps and battlefield 3). The multiplayer is much more cpu intensive for example.
lag is caused by internet connection
fps drop and stutter is cause by the machine
Do you have rubberbanding issues? (eg you are going fowards and you are suddenly moved backwards)
On my old machine I played fifa 14 and lag only happend because the internet connection will see on my new machine
No nothing the game played extremely smooth:p
btw, FIFA is a completely different game, it has massive issues on everything sue to EA's crap servers.
Use either a synthetic benchmark so you can see how you numbers stack up compared to everyone else, or play a game you play a lot and see how it performs.
My run
Max
Good or bad?
My in game set up
How will my games run?
Is this a good score and is everything fine?
