Innocent159
Circulation is BAD. You want air to go in and then directly out. Since heat rises, the air goes up, gets blown down, rises again, and is stuck in that loop. If the top is exaust its better for airflow and temps.
Will change it tomorrow and run a stress test again and compare results and noise level since here's a little noise when you go near to the cases, is that normal?
