Hi to you all from DownUnder....!
Déjà vu was completed earlier this year, however I only stumbled in OC3D'd forum the other month so I have decided to post up a build thread for our friends primarily based in or around the UK. In particular those who frequent OC3D and may not venture much further than here....
I'm not new to water cooling and have dabbled with it over the years since around the early 90's.
Here is an old pic of mine - pretty messy huh...! Water cooling was fairly unique in those days and in many instances we had to cobble up our own bits and pieces.
Back in 2014 I built a water cooled Corsair 900D - A fairly minimalistic affair basically just to get my feet wet once again after a long hiatus from liquid cooling over a number of years.
Roll on into late 2015 and I decided to get serious in regards to carrying out a 'proper... B)' water cooled build incorporating hardline.
My heart was set around the Caselabs SMA8 which has a similar form factor to my previous 900D build and one that I wanted to stick with for now.
So with some ideas in mind - I bit the bullet and purchased a Caselabs SMA8 to commence Déjà vu.
The name Déjà vu came about since many other builds have been based on SMA8 cases previously (which no doubt you guys have been bored to death with) but I wanted to set mine apart somewhat with what I consider to be some unique build attributes.
So with all that out of the way lets get started...:
Note that this build is not sponsored in anyway - damn, had to pay full ticket for all the items... :nopity:
Contents:
Case: Caselabs SMA8 with 39mm extended top & lower pedestal options.
Reservoirs: XSPC 270 Photons x2 - Modified for improved performance and configured for parallel operation.
Radiators: Alphacool Monsta 560 (Lower Pedestal), Alphacool UT60 560 (Mid Section), Alphacool XT45 560 (Top - requires case modding).
Pumps and Top: Aquacomputer D5 USB x2 matched to EK Dual CSQ Top for serial connection of pumps.
WC/Fan Controller: Aquaero 6XT - Coolant Flow to be monitored with MPS400 sensor and mechanical rotameter.
Fittings: Bitspower Silver Shining utilised throughout build. 16mm Bitspower hardline/acrylic dual O-ring compression style fittings (BP-EML16) for mating to acrylic tube.
Tubing: Bitspower 16mm OD, 12mm ID acrylic.
Fans: 24x Phantek PH-F140MP fans
Waterblocks: EK Supremacy EVO Nickel + 2x EK FC780
Main PC Hardware:
Motherboard: ASUS ROG Maximus VIII Formula
CPU: Intel I7-6700K
Memory: Corsair Dominator DDR4 4x8GB @ 3200
GPUs: 2x EVGA 980Ti Classifieds
SSD: Samsung 950 PRO NvMe M.2 - 512GB
HD: WD Black 2x 2TB
Power Supply: Corsair AX1500i
Internal USB Hub: NZXT IU01 - for Aquaero and associated USB components
Here is a complete list of all the Bitspower fittings used within Déjà vu:
As you might guess, Déjà vu is built using straight tubing with couplings. I'm not a huge fan of bent tubing. While I can appreciate the clean flowing lines one can achieve by bending acrylic tubing I specifically wanted a straight vertical/horizontal look for my tubing runs to give it that tough industrial type stance.
Stay tuned for more to come....
Main PC Hardware:
CPU: Intel I7-6700K
HD: WD Black 2x 2TB
