Your right, I should consider myself lucky I lasted this long without having to try rma something.Thing is youll get failures with ANY product, Ive actually not heard about many of the 290 or 290X's going yet
On Sapphires site it says they are void if you remove the heatsink/cooler.Don't think attaching waterblocks voids warantees. Or i guess its brand dependant?
Also would anyone know is it sapphire I do the rma through or overclockers.co.uk? It was bought 2nd of November is that has any impact on it.
In this case the waterblock hasnt even arrived yet, they have it in the post to me as we speakYou RMA with OCUK - dont mention waterblock just make it look like its never been off.
Is there a way to check its Elpdia without removing the cooler?I saw on another forum that people who get cards with Elpdia ram seem to have problems with either dying, early or just giving black screens when you put the cards under stress.
Not all cards with Elpdia have problems though.
Hope you get it sorted soon though.
Thanks
Just wish I never sold my 2 7970's and gtx 670 right before christmas, now i'm without a workstation.
Would RMA take long for a card? Just wondering as cant be a month without a card and would have to order another one in the meantime.
Hopefully, mine is as little hassle as that too replace.My Powercolor 290@290X died on me while benching, probably due to pulling 1.3v through it. Temperatures were in check, so I guess it's a matter of bad luck with some component not being in shape.
EDIT: RMA'ed it no problem
I have to wonder was that the case with this one as it was overheating from the beginning and then just failedI have nothing good to say about sapphire unfortunately I've had cards brought to me with snapped PCIe slots even the power socket solders cracked off seems they use poor quality PCBs and solder.. I've not had the misfortune of dealing with their RMA procedure thankfully but I can tell by visiting their forums and Facebook page they are a company to avoid... for now at least.
Will stick with the likes of gigabyte, msi, evga, gainward, pny and kfa2 that have decent customer service and rma support from now on.
