D Dav0s New member Nov 7, 2005 #41 ram at any divider wont work frag, even ram running at 150mhz didnt pass pi so it cant be ram. would chipset voltage help at all? ive upped it a bit. any other tweaks i should think about? sorry im still not that good at oc'ing a64's
B bloodthirst New member Nov 8, 2005 #42 Dav0s said: ram at any divider wont work frag, even ram running at 150mhz didnt pass pi so it cant be ram. would chipset voltage help at all? ive upped it a bit. any other tweaks i should think about? sorry im still not that good at oc'ing a64's Click to expand... i dont think chipset would need any voltage changing, maybe getting some more volts into your ram, have you not tried that...
F FarFarAway New member Nov 8, 2005 #43 name='bloodthirst' said: i dont think chipset would need any voltage changing, maybe getting some more volts into your ram, have you not tried that... Click to expand... Negative. I've found I can really push the HTT up on my board if I put a few more volts into the chipset and LDT
B bloodthirst New member Nov 9, 2005 #44 name='kempez815' said: Negative. I've found I can really push the HTT up on my board if I put a few more volts into the chipset and LDT Click to expand... fair enough
