atuljain.er
Creative T7900 (7.1) - 'Center' not working. All others fine
Hello
A very strange problem with my Creative T7900. The center channel is not producing any sound. All the other channels are working fine.
Here is all testing I did-
There is a strange 'hiss' from the center speaker when all others are playing audio. So I am sure it is connected but not playing any audio.
I am unable to find any solution. I tested that the sound is being passed from PC to Subwoofer, and that the Center is well connected to the jack. Just that the subwoofer is not passing the center audio signal.
Here is system config-
Win 7 64 bit
AMD processor
8 GB RAM
Gigabyte 970 DS3 motherboard
Onboard Realtek HD audio capable of 7.1
Please suggest.
Thanks!
Hello
- I tested the audio source by swapping jacks and inputs are fine. There is sound being passed through from all the channels of PC.
- I tested the connected audio cables. All cables are good.
- I tested the Center speaker by swapping channel with it. The speaker works fine and not faulty.
- I tested the speaker jack(on subwoofer). The jack is fine because it plays audio when other channels are played through it.
- I tested Realtek and Win 7 utilitiy to check all channels. When I play just the 'center' channel, no sound is heard.
Win 7 64 bit
AMD processor
8 GB RAM
Please suggest.
Thanks!
