CPU runs only at half speed
beechboy
Hi !
My mainboard is ECS P4S8AG. This board can clock 1.4 ... 2.8GHz (auto select)
FSB : 533MHz
CPU installed : Intel P4 (Northwood, 478 socket) 2.8GHz
My RAM is rated PC3200
Bios (POST) says the clock runs at 1.4GHz
I did a speed test (with CPUSpeedPro)which also reports 1.4G
i.e. MOBO chooses wrong freq.
I placed a different CPU (P4 3GHz), and the same thing happened : it ran at 1.5G
How can I override the board's auto select and make it run at 2.8G ?
It should, shouldn't it ?
I don't know enough about freq multipliers/ratios to solve this.
Thank you,
BeechBoy
there must be some kind of eco rubbish thats clocking the cpu down ....
i honestly wouldnt know where to look ...
Have you tried running an application or put the processor under load? Maybe the CPU just clocks down while idle.
Hi guys,
I found out what's wrong : CPU doesn't really fit the MOBO.
Thank you for the replies, BTW.
The CPU is 2.8HGz FSB800.
==> It runs at 2.8G if clocked at 200M (multiplier is 14)
MOBO is FSB533, thus can do 133MHz. But for unknown reason it chose to do 100MHz.
This is why I had 1.4G speed. 100M * 14 = 1.4G
Solution : Used BIOS to first set clock at 133. Then made some more increments.
All works fine at 143M.
This gives 143 * 14 = 2GHz.
Still not full trottle, but I can live with it. :-)
