Hi everyone
It's been some time since I've upgraded my system, but as of lately I have been considering extending on my current CPU loop to a more comprehensive CPU+GPU loop. The problem is I have a mid tower case (650D) with a single 240mm radiator (XSPC RS). The reservoir I am using is a XSPC dual 5.25" bay res with an integrated Pump.
1) Firstly would I need to replace my reservoir, presuming I will need a stronger pump? I've been thinking of purchasing a similar dual bay res but with a separate pump that attaches on to the res?? The thing is I don't know much about pumps other than they come in various different thread sizes and with differnt tops of all sorts...
very confusing
2) Will a single 240mm Radiator be sufficient for a CPU + GPU build? I have 2xGentle Typhoon (1850rpm) on pull above the radiator... if not where could Ipossibly fit another rad? I would probs need more tubing lol
For reference, my current tubing dimensions are7/8" ID x 5/8" OD andI have a single GTX 580 but the PCB is custom... I will be using EK full cover waterblocks and backplate if all goes well.
