Hey, decided to go overbudget, and gone with that famous d-tek fuzion. anything else to improve/change? Cheers for all the help and comments, thanks guys, really appreciate it
edit: damn it, just noticed they havent got any GTX blocks
Thermochill one is obviously the best choice, pa120.2 is £50, so add the £10 you saved from the res, get another £20 and boom, sorted. Do things right and only do them once
Aye...Smiffy is right. Why bother installing kit which is only a few quid cheaper than something which will pwn it in terms of cooling capacity....save up a little longer and treat yourself...you'll only end up replacing the kit in a few months otherwise....:wavey:
