Rastalovich
Core Temp is a compact, no fuss, small footprint program to monitor CPU temperature.
Now Vista ready! (x86 and x64)
*cough* no hack required ?!?! *cough*
Site for download
Version 0.99 - 18th May, 2008 (direct copy/paste from website)
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
Site for download
