Cooling
danb00
hi im new here, Boardy sent me here
im thinking about getting vapochill is it worth it? what one should i get?
AMD x2 3800 with stock coolers, 1gb ddr ram and a x800gto 256 gcard
current temp is like 27c idel and 40c heavy load
if not how else can i improve cooling in my pc?
Alright mate welcome to the forums
With cooling it depends how extreme you wanna go?
You could go the watercooling route if you like nice & quite, plus you would probably get an extra 100 - 150 Mhz overclock with a good setup!!!
Or the phase change route, either a Prometeia 2 or a vapochill LS, these systems last for years & are great value for money, you can get a £100 cpu & make it run faster than the £700 cpus, with your x2 3800 there is a chance of the dreaded coldbug but not many 3800 suffer from this which is good, with a phase change system you could probably get upto 3Ghz, which will give any system a massive preformance boost!
Hope this helps a bit!
Dave
Coldbug stops the onboard memory controller from getting to its highest possible speed. Either that, or wont let the computer boot at all. Theres a temperature threshold on some A64 CPUS, and below this, the HTT stops playing properly.
name='BigAndy' said:
What exactly COLDBUG do to your CPU?
often the pc doesnt start, and if he does there are frequently reboots ( i had ervery 30 secs a reboot, a friend only all 5 min)
name='Xtasy' said:
the fx57 , an new produced opterons, but there as usuall exeptions :)
Fx57s aren't bad for coldbug until you get to ln2 temps - they fly on cascades. It's AMD dual cores that are worst for coldbug.
Almost all the FX60's suffer from it still a great chip though:p
P.S Nice to see ya back Gollum thought we had lost ya there:D
you are right, i thought fx60 but posted fx57 ^^ sry
FX-57 @ -50 ish
