my setup is
asus p5w ph deluxe
E6600 2.4ghz core duo
2gb corsair 6400 ram/dual channel
1x320gb sata2
1x400gb sata2
1x tv tuner card
Ati x1950 pro
1x dvd rw
hiper 580w psu
case - asipre x-crusier
i have
1x 120mm exhuast fan
1x 80mm fan blowing out of the top
2x 80mm fans on the front (intake)
1x stock intel fan (soon to be Arctic Cooling Freezer 7 Pro )
1x side panel duct to channel cpu
NB: the psu has a 120mm fan which either draws air into the psu from the case or blows out, this is very close to the 120mm exhaust fan and cpu fan, not sure if this is having an affect on the cooling?
All fans are blowing at max, there is no managment on the fan controls being used
current idle temps with everest and thermal analysis tool - cpu temps are the same with both programs
from everest
Temperatures
Motherboard 46 °C (115 °F)
CPU 40 °C (104 °F)
CPU #1 / Core #1 52 °C (126 °F)
CPU #1 / Core #2 50 °C (122 °F)
GPU 56 °C (133 °F)
GPU Ambient 50 °C (122 °F)
Seagate ST3320620AS 43 °C (109 °F)
Seagate ST3400633AS 38 °C (100 °F)
Cooling Fans
CPU 2789 RPM
Voltage Values
CPU Core 1.24 V
+3.3 V 3.33 V
+5 V 5.15 V
+12 V 10.40 V
+5 V Standby 4.99 V
this is not an overclocked system and is all running at stock speeds
one thing i will say about this case, the front design is really poor, as it has a front door on it, which is mostly closed, so the two 80mm intake fans are not having a great affect on the cooling i don't think, and not only that the air holes on the front of the metal case, where the fans get mounted are not ideal and are some what hindered.
as pictured here
so there is my current setup, is it wise having 2x 80mm intake,(i can only fit 2x80mm at the front) with 120mm exhaust and 1x80mm blowing out of the top
also the side window has a vent and also a air duct which is aligned over the cpu fan
as pictured here
any suggestions on how i should have the fans etc
if you got this far
thanks for reading
asus p5w ph deluxe
1x320gb sata2
1x400gb sata2
1x tv tuner card
Ati x1950 pro
1x dvd rw
hiper 580w psu
i have
from everest
Temperatures
CPU 40 °C (104 °F)
GPU 56 °C (133 °F)
Cooling Fans
CPU 2789 RPM
Voltage Values
CPU Core 1.24 V
+3.3 V 3.33 V
+5 V 5.15 V
+12 V 10.40 V
+5 V Standby 4.99 V
as pictured here
as pictured here
if you got this far
thanks for reading
