Changing the size of the tubes in a loop...
Tommo120
Is there any way that you can go from one size tube to another within a loop? This is my first time ever setting up a water cooling system and basically what Ive done is change the size of the tubes at the last second and now my waterblocks are a smaller size... Has anyone got any suggestions? Other than the obvious option of buying different waterblocks...
Thanks in advance
Well, few small problems, i haven't actually managed to get them off yet but the barbs definitely don't fit in the holes, even if they did, the pipes wouldn't go on because of the barbs being so close together... Any other suggestions?
UPDATE: I managed to get the barbs off my GPU Waterblock and my other barbs don't fit at all.
Ok, so heres what i have:
1/2" Tubes
1/2" G1/4 barbs
and it seems my waterblocks have an ID of 8/9mm
I thought maybe a converter of sort that goes from 1/2" to 3/8" but i can't seem to find one anywhere
Please can someone help!
what exactly are you trying to change the barbs on, model etc etc?
They all have the same thread, so the new ones should fit nice and snuggly.
Bit weird them not fitting. You got any pics?!?!?
1/2" tubing is the best imho. Much nicer temps, looks big and sexy too XD
