Xenomorphical
Ok so today i had a little project at a relative to install a SSD and put windows on it.
So, pulled the case out from underneath the desk and notices some dust on the cooler master cosmos case (older model)
So since i allready brought my magic brush i popped the roof off to clean it.
That's where the "fun" started lol
The roof:
If this is the main air OUTlet you can kinda imagine what was to come on the inside.
One of the top fans.
Cables pulled over the GPU and mobo, dust inside the power cable sleeve? yikes :S
Radeon 7970 and the bottom case fan (only inlet fan)
Keep in mind the 7870 has a BLACK pcb, not white / grey lol
As expected the CPU cooler wasn't much better off.
Did anybody identify any new lifeforms on the blades of this fan?
Solid wall of dust behind the fan. the next step? a indoor house fire.
Everything cleaned and installed. We ended up taking everything out for cleaning, even took the shroud off the 7970 to clean.
Final result: 34C idle temp on the cpu and 70 bucks in my pocket
On top of that, a new rig is planned in the future and guess who will be doing it
The roof:
