Hi,
I got a cooler master enforcer yesterday and the window had some smears on it after i assembled the pc so i used a glasses cleaning cloth to wipe it over now if you look at it from the side it looks like someone rubbed sand paper over why do they scratch that easy.
The case is awesome its only the window
Tom reviewed it and said it was good care to elaborate why its a waste of money?
They fall apart like a muffin in the rain then need replacing. Better to just get the higher price case you would end up replacing the cheap case with and be done with it
I'm pretty happy with my cm690ii. Its not showing any signs of wear, has an awesome layout, and was only $80. There's other cases out there too that are like this. Your blanket statement isn't true. Now when you start looking at the really cheap cases <$30, then I'd agree with you. I'm pretty sure the rivets in some cheap cases are made of silly putty.
LOL 'Hybrid Flop'.
I think as ever there are bargains to be had, cheap cases which just last. Of course you have shi**y cheap cases, but there are some gems.
And you have some very poor expensive cases too, although generally build quality is very nice.
I bought a case for £19 of ebay was cheap felt cheap but it never fell apart or i never had a prob with it for 2 years i only changed cause i wanted a baclk interior and more fans.
As for this case window it looks like someone with sand paper and a grinder have gone all over it i wipe it with a micro fiber cloth but it still scratches it.
EDIT: also, for cleaning dust away i use a make-up brush.... they are fantastic at getting rid of it![]()
how wouldd i attach it?
