Edge
Hey guys, tis I again.
So I basically settled on the Fractal Define Mini, but without much knowledge of the case I'm trying to figure out what I should do about cooling.
For the Case
I'm going to go for positive air pressure, so I'll have 2x120?mm intake fans at the front, and one 120mm at the back as an exhaust. What fans suit the minimalistic aesthetic of the Fractal Define Mini while maintaining good airflow and silence?
For the CPU
I've never bothered with aftermarket CPU cooling before as I can't overclock on this motherboard, but I've noticed one of the main contenders for noise in my case is the terrible stock Intel cooler, so I'm going to replace it.
What are the best low profile budget CPU coolers? Most of the ones I've seen are huge and won't properly fit my case (I'm using low profile RAM, btw). Also, should I pick up an extra fan to replace whatever comes with the aftermarket cooler? I guess that depends on the recommendation.
My Specs will be as follows:
Fractal Define Mini
Intel i5 3570 CPU
Gigabyte GA-H61M-USB3-B3 H61 mATX Mobo
Sapphire R9 270x 2GB Vapor-X
Corsair XMS3 2x4GB DDR3 RAM
Corsair CX500m
500GB Seagate Barracuda
1TB WD Caviar Black
So I need a CPU cooler recommendation that fits the Mini, and three case fans (potentially a fourth fan if the CPU cooler fan is kinda weaksauce).
Halp please!
I'd prefer not to spend a fortune on a cooler, so cheaper is better, but I'll pay if it's worth it. Less than 50 quid is optimal.
For the Case
For the CPU
Fractal Define Mini
Intel i5 3570 CPU
Corsair CX500m
1TB WD Caviar Black
Halp please!
