Cant hit over 298mhz HTT
maverik-sg1
Okay guys,
I purchased Gollums PC5000 OCZ series ram and it fantastic!!
Will memtest stable 326FSB @ 3-4-4-8
I am running 296 @ 2.5-3-3-6 the reason?
My trusty steed the FX55SD is not stable above this HTT/FSB speed.
The interesting thing for me in teh whole BH5 versus TCC5 thing is that at the bench spped sI can run at the scores are a match to those by BH5 - if only my CPU could reach that FSB/HTT I could then run 11*321 and that would, I believe - kick some ass big style.
I am off to scorchio's on Wednesday to try it in his rig to see if we have more joy there - will keep you posted, fingers crossed.
If anyone knows the best TCCD/TCC% BIOS to use - post it here, we'll give a go.
The Coach
i have heard hell fires bios revision of the bios yr using (510-2) is very good best bet is to look on xs though
Phil
Have you tried running the cpu with the mach 2, the cold maybe knocking your max clocks down......
If you look around Xtreme you will find 95% of people get thier high clocks (300Mhz+) are on air cooling.....
Well the fact that it will run memtest 1:1 at 326 but not windows is the odd thing although I agree the cooling may well be the problem as we all know the controller goes crappy when it gets very cold from dumo's cascade experiences.
Maybe I need to convert the mach into a waterchiller and have a complete watercooling loop running around 10-16 degrees?
Although the strange thing is Gollums rig on R507 cooling, could reach 320+ Mhz HTT/FSB.
as I said the RAM is great I know coz I can still memtest it stable above 312mhz, just cant boot at that speed.
The Coach
Nah it crapped out in windows at about 320 but memtested much higher same as yours. I guess it only got 20mhz higher because the controller in the 57 is slightly better than in the 55.
