Cable needed (not so popular)
theDTP
I need this cable (LINK) but in the next few days in the UK.
Could anyone point me in the right direction, that's be truly amazing. I need to get this new build back to it's owner and the GPU fans are stuck on 100%.
(some info on the situation HERE if you are interested).
He knows nothing about the internals of a PC and doesn't care how it looks inside (I still went OCD with the cable managment). He just likes to game.
Found these for the male mini end but I'm only seeing that cable on Moddiy, you could easily make your own though.
Ah yeah, connectors. I'd still have to wait for them to be delivered which will take just as long as the ready made cable, FrozenCPU isn't in the UK is it? Also if I could get the connectors myself wouldn't I need a crimping tool? :mellow:
They'd have to be soldered I'm afraid. I'm just waiting for a reply from my electronics supplier to see if he has the sockets. ;)
Ah yeah soldered on to the male mini then crimped at the other end to go in the female 4pin PWM connector. Seems you know your stuff, if the supplier has the required connectors and you are up to the job, that would be great :)
No worries, if they have the required parts and you want to make the cable I need then let me know here and I'll open a new thread in the relevant section of the forum ;)
The Connector your looking for is a Mini/Micro JST or Micro ZH 1.5mm socket, I have found them.... but they are on back order via my local place and the only other place I can get them is eBay with a 16 Day wait from China and a minimum order of 20. :eek:
I've also checked with RS Components too and they have none in stock.
Ah man :( he will have to deal with 100% fan speed then until the cable gets here from Moddiy then, can buy 1 cable for less than £2 about £8 shipping haha, 7-14 days delivery.
Either that or he can process the RMA himself :mellow:
EDIT: Is THIS not it?
EDIT EDIT: Or maybe not, will it cause harm getting the one I linked?
No not that cable. I can get the socket but as we've discovered minimum order of 20 and 14 days delivery just not worth it even for a few quid.
