Hi,
I have a few spare monitors laying around my house doing nothing fun ... but i was thinking it would be nice to hook my Wii into one .
I intended to do this using a Signal processor (component/Scart to Vga/Dvi/HDMI) while on a hunt i saw this
http://www.tvcables.co.uk/cgi-bin/tvcables/BTXL18015-Component-VGA-Cable.html?id=mTRqcMuN
A component to VGA cable !!!!!!
I seriously doubt this will work as it takes a Y'PbPr(component) signal and hooks it straight to RGB(vga)
My problem with this it that Y'PbPr Is essentially YUV with different scaling and YUV needs to be processed into RGB -- something a cable alone doesnt do (processing required illustrated |here| )
Does anyone have any experience here ?? Is it posible (it may be possible this cable uses inline analog conversion)
Specifically in relation to this
I dont believe the Wii can so RGB over Component
EDIT :: I also could go Component >> HDMI || HDMI >> DVI || DVI >> VGA
But I could feed my 2 year old newphew chocolate , cola and sweets all day and his nappy would look like less of a mess
Modern game systems (like the PlayStation 2, GameCube, Xbox, Wii, Xbox 360 & the PlayStation 3) use the same connector pins for both RGB and component video, with a software or hardware switch to determine which signal is generated.
