JayCobs
Long set up story shortened, I've been compiling components for my build for close to 2 years.
I currently have:
GA-990FXA-UD3 rev. 1.1 BIOS F9
Corsair CMZ16GX3M4A1600C9 [only using 2 4GB sticks]
MSI R7950 Twin Frozr 3GD5/OC Radeon in Crossfire
AMD FX-8320 Vishera 3.5GHz 8-core
Corsair AX1200
No components are overclocked. Memory, CPU, and GPUs are liquid cooled.
I am currently using 1 27in 1080p LED monitor, and 2 21.5in 1080p LED monitors. I only game on the 27in.
On another website a member began tearing into my build component-wise saying "You wasted so much money to get no power!", "Why did you buy such a pathetic motherboard?", "I thought this was gonna be a high-end PC, turns out it's just some 8 core AMD.", "What a noob mistake buying a 8 core CPU!", "A i5 4 core will beat you in a benchmark using 8 cores.". I didn't understand that last one...:huh: How does the member know what I spent?? Weird... The CPU was only $99USD on Black Friday - why not buy it? Now according to this member I am causing a bottleneck by not using one of the many Intel CPUs he mentioned. However, when I pressed the member to give me a component list that will liberate my GPUs the responses ceased.
Is there a way to tell for sure my current config is bottlenecked? Considering how diverse a build can be, how can I determine if am getting everything out of it? I don't have a selection of benchmarking tools. I do have MSI Kombustor. Any help would be most appreciated. If I have not supplied enough data here, let me know what is needed. This is the first time I have considered fine tuning my config so, be gentle!
I currently have:
Corsair AX1200
