richardo11
Hi guys, I am about to build my very first PC, the only way to get what I want, so I am a bit scared and confused; the PC is meant most 3D design like 3D Max such I am going to start to learn, though I occasionally do some gaming but nothing serious.
I am not a guru. Here are my choices:
Case: Corsair Obsidian Series 800D.
PSU: CORSAIR Power Supply 1000W HX.
(I heard that there is some complains that this PSU breaks often?? I had seen a video in YOU tube of a German guy looking the insides of this PSU, and, well … it is very worrying. Any recommendation? Also I read that the wirings are kind of short for a full tower.)
CPU: INTEL Core i7 980X/ 3.33G LGA1366 12MB 6.4GT.
Motherboard: ASUS RAMPAGE III Extreme.
RAM: CORSAIR 6 GB (3KIT) DDR3 1333MHz/ CL9/ 1.65V/ XMS3 with Classic Heat.
CORSAIR 6 GB (3KIT) DDR3 1333MHz/ CL8/ 1.65v/XMS3 - CL8-8-8-24
CORSAIR 6 GB (3KIT) DDR3 1600MHz/ CL9/ 1.65V/XMS3 with Classic Heat
CORSAIR 6GB (3KIT) DDR3 1600MHz/ – 8-8-8-24
CORSAIR 6GB 83KIT) DDR3 2000MHz/ - 9-9-9-24 / 1,65V/XMS3
CORSAIR Dominator/ 6GB (3KIT) DDR3 1600MHz - CL8-8-8-24/1,65V/XMS3 w/Fan& Connector
CORSAIR Dominator /6GB (3KIT) DDR3 1600MHz - CL7-8-7-20 /1,65V/XMS3 with connector
CORSAIR 6GB (3KIT) DDR3 1600MHz/ CL7/ XMS3 -XMS Heat Spreader
CORSAIR Dominator 6GB (3KIT) DDR3 1600MHz/ CL7/ GT w DHX and Airflow Fan
CORSAIR Dominator 6GB (3KIT) GT DDR3 2000MHz XMS3 DHX, CL8-9-8-24, w/Fan& Connector, 1.65v
CORSAIR 6GB (3KIT) DDR3 1866MHz/9-9-9-24 - Fan
OCZ Gold Low Voltage 6GB (3KIT) 1866MHz 10-10-10-24
CORSAIR Dominator GT 12GB (3KIT X 2) DDR3 1866MHz
CORSAIR 12GB (3KIT X 2) DDR3 1600MHz/9-9-9-24
OCZ 12GB (3KIT X 2) DDR3 /1600MHz/ CL 7-7-7-24 Platinum Low-Voltage 1,658
(RAM is kind of hard choice; I don’t know what will be the better for my system).
These are my ideas. What would you choose? Why?
(I read that that Intel iE7”accept” memory up to 1033, what if I use 1866 or 2000?)
I also read that is not convenient to fill up all the memory slots, better for a future upgrade will be 12GB (3x4GB Kit)
Cooler: NOCTUA NH-D14 CPU
(Have the extreme III the two connectors for the fans of this cooler?)
(What about water cooling?)
Video card: SAPPHIRE Radeon HD 5870 2GB GDDR5 PCI-Express 2.0, "TOXIC Edition"
SAPPHIRE Radeon HD 5870 2GB GDDR5 PCI-Express 2.0, "VAPOR-X" Full-Retail
SAPPHIRE Radeon HD 5870 2GB GDDR5 HEXAD PCI-Express 2.0, Eyefinity 6, 6xMini-DisplayPort
SAPPHIRE Radeon HD 5970 2GB GDDR5 PCI-Express 2.0
I heard SAPPHIRE is intended to produce a device to evoid to buy a display with Display-Port. It is already in the market?
I would like as much displays as possible but not using display port. It is possible? How?
Reading the Extreme III manual (such I downloaded) about the Graphic Cards is saying something about setting the IRQ’s. I have a slight idea about what is it and what is for, but setting this IRQ is confusing, in all the You-Tube videos I watched and pc making manuals I read, not a single one mention that.
Should I be concern or do something?
HD: Western Digital 300GB Raptor SATA 10000rpm 16MB RTL
Western Digital Caviar Green SATA3 1.5TB
Optical Drive:
PLEXTOR PX-B940SA (Schwarz) Schwarz
Keyboard: Logitech G19 Gaming Keyboard colour Game-Pane
Mouse: CoolerMaster Storm Sentinel Advance Gaming mouse
(You will say, if you don’t intend to play, way a gamming keyboard. Just for multikey programming, 12 hot keys, USB x2 ports … Disabling (For ONCE) disturbing Windows warnings, messages, tip-toes …etc)
I plan a second Graphic Card in future. Have enough PSU with the one I chose?
Do I forget something that you will recommend?
Thinking that I do basically not play games and I do not care too much about sound, Should I need to install a sound card, or is included into the motherboard? (Sorry is the question is stupid)
I apologize for this long post, this adventure, although I feel confident is standing up the hair of my back.
I can easily guess that this is not my last post, I promise to keep them shorter though
One last thing. Recommendations for a good water cooling system for this case?
Optical Drive:
