RichieSams
Hello people of OC3D!!
I finally got the time and money (yay summer internship) to do a watercooling build. I've always enjoyed watching the builds here at OC3D and now I get do do my own. On the the build itself!
The Theme
I always like all the small highlights people put in their builds (sleeved cables, backlit blocks, neat tubing runs, etc., but it always irks me when they just drown it out with light, light everywhere. So for this build I wanted to try to 'Accent' the interesting parts of the build with selective lighting schema (more on that later) and in the end, have a badass look, without blasting it.
The Parts
Most of this is set, but there are a couple that have options that I would like your opinion on. More on that later.
Main
Case: NZXT Switch 810D
Motherboard: ASRock Z77 Extreme4
CPU: Intel Core i5 3570K Ivy Bridge
RAM: G.SKILL Ripjaws X Series 8GB (2x4GB)
Video Card: EVGA Reference GTX 680
SSD: SanDisk Extreme 120GB
PSU: Cooler Master Silent Pro 600W (I'm looking for a 850W PSU to go on sale, maybe the NZXT Hale82. Any thoughts or suggestions?)
Water Cooling
Top Radiator: Alphacool NeXXos UT60 420
Bottom Radiator: Alphacool NeXXos UT60 280
CPU Block: XSPC Raystorm
GPU Block: XSPC Razor 680
GPU Backplate: EVGA 680 Backplate
Pump: Swiftech MCP355 / Laing DDC 3.x
Reservoir: XSPC DDC Reservior top
Tubing: PrimoChill PrimoFlex Pro LRT - Clear - 7/16 ID
Fittings: Assorted Bitspower Matte Black Compression fittings
140mm fans: Akasa Apache Black (still deciding)
Everything in main except the case is from my build I did in May and already bought. The case arrived today and the radiators are in the mail. Everything else is on hold until I can figure out some more specifics of the build. Speaking of which, the things I still can't decide on:
Pump/Res combo
I'm happy with the performance of the XSPC res top, but I'm curious if any of you know of pump/res combo that is a cylinder. Of course, with similar performance. This is mostly for looks and pretty minor at that.
Fans
I really like the Akasa Apache Black because they have 2.76 mm H20 static pressure and they're only 22 db. I know the B-Blasters have 3.16, but they're 36 db. Akasa Vipers have 3.12 mm H20, and only 26 db, but that yellow is so bright. Lol. Any other fans I've seen (Bitpheonix Spectre [Pro], Thermaltake TY140, Corsair AF140) all have terrible static pressure.
Feel free to comment with any thoughts or suggestions.
Flow diagram
The Theme
The Parts
Main
Water Cooling
Pump/Res combo
Fans
Flow diagram
