195kg back squat cleared 3x3 sets two and three were perfect. Next week I'm doing 2x3 on 200kg... GETTING STRONG.
Already strong dude.
already strong dude.![]()
:3 :3 :3 meow.
No no I don't mean "F you I'm already strong" :lol: I meant YOU are already strong.![]()
Is this a two way miss understanding? You've missunderstood my comment and I've been using :3 incorrectly? Its a cat face yeah???? Like a smile but a cat... >.> damn my worlds over.
This looks better and you'll get better results doing something like this. Take as long a break as you want while doing your 3x3 or 3x5 no more than 10 minutes though.
1x5 @ 20kg
1x5 @ 40kg
1x5 @ 60kg
3x3 (max 3x5)@ 100kg This is where you get your gains, anything else and you might as well not dead lift.
1x1 @ 105kg (not needed)
1x6 @ 60 kg (not needed)
LOL yeah I didn't get that, I thought it was like a confused face and the meow was like "Oooo meow bitchy". :lol:
1x5 60kgs
1x5 80kgs
5x5 90kgs
Incline bench
1x5 20kgs
1x5 40kgs
3x5 60kgs
Flat bench
1x5 20kgs
1x5 40kgs
3x5 75kgs
Again the slight drop in weight but increase in sets/reps hurt more than chasing max weight.
Deads again tonight , i'll follow your plan ahimoth.
Overheard this cute girl that she loves guys with huge arms and a wide back......guess who's working twice as hard on back and arms days?![]()
I'm just not making the progress on Squats anymore, I guess I need to mix it up a bit, and maybe cut Squats out of the routine for a while. The best I've done recently is 125kg for a set of 3 well below parallel before Christmas.
Leg workouts without squats, now there's a thought! ^_^
Deadlifts
2x6 20kgs
1x6 40kgs
1x5 60kgs
5x3 100kgs
Last set of 3 was good and not too much of a struggle. Will change this next time to 4x4.
Well with the kind of weights you're lifting, I don't think I want you choking me. Particularly since I'll actually be down under later this year for a while, although likely not in Melbourne. ^_^I'm going to choke you if you stop squatting>.>
125kg for 3 is decent. Can you maintain it? Are you cutting? Are you recovering correctly? How often are you squatting? Can you do 100kg 5 x 5? Why are you not making progress on squats how much weight have you tried to add to your squat? Are you doing high or low volume sets? 1x3 @ 125 isn't as good as 5x5 @ 100 or 3x5 take the weight down and build up in 5kg increments with a light and a heavy day squat session.
80% of 125 is 100kg so you're around that ballpark. Are you dropping your chest out or into the hole? Are you squatting barefoot or in runners? Squatting in runners is terrible get squat shoes, squat barefoot or use old school shoes as the next best thing. What are you finding hard about the squat?
I'm more than happy to try and help you work through this and break your plateau.
At the minute I'd be cutting. Not too much of a cut, my caloric intake is just ever so slightly below my TDEE, I probably should re-adjust it again. I weigh about 79/80kg.
I squat once per week, and it's normally 3x5reps that I do. I took the last two weeks off just for a break, I got back to it today. I was doing 100kg for 3x5 before last week, but I did 95kg today since I took a small break, and it's 3x5 I normally do. I don't tend to shoot for maxes all too often, and the squats are part of a leg workout complete with lunges/step-ups, and I always squat in my socks.
I guess I need to be more aggressive with adding weight, and not be as afraid of failing since I do them in a rack with catches anyway.![]()
On the bright side of things my legs are nice and sore today. ^_^That's the attitude attack the weight!
