right, been promising for ages so here goes..
I'm using a 120.3 rad in my project for GFX card, HD & maybe NB, its a pretty big rad so needs a bit of care to get it installed correctly & not wreck the case..
there are some templates out there but Ive never found one that is exactly correct, most are off by a few mill & when you are cutting three holes that can bugger things up..
Best thing to do is make your own, basically cut a piece of paper the same size as the rad & place on top (I use a bit of spray mount to ensure it doesn't move)
rub where the screw holes are with your finger & it will make a nice indent in the paper, punch through the centre with a pencil, repeat for all the holes..
http://www.mawhyte.pwp.blueyonder.co.uk/images/guide/1.JPG
now remove paper & draw lines from hole to hole to find centre point this will be used for the hole cutter..
http://www.mawhyte.pwp.blueyonder.co.uk/images/guide/2.JPG
Ill be cutting from the inside of the case lid so mask up the outside to prevent scratches etc..
http://www.mawhyte.pwp.blueyonder.co.uk/images/guide/3.JPG
then flip it over & mount the template.. I would suggest taping it down well once you have centred it to make sure it doesn't move while punching. Using a centre punch, punch out the screw hole locations & the fan centre.
http://www.mawhyte.pwp.blueyonder.co.uk/images/guide/4.JPG
remove the template & store for later use
now onto the fun part.... (will update later tonight..)
