BitFenix Pandora and Atlas Pictured
WYP
News Guru
Here are the first pictures of two of Bitfenix's newest additions to their case lineup. Presenting the Bitfenix Pandora and the Bitfenix Atlas chassis.
The top smaller case is the Pandora. It is designed for mini-ITX form factor, with dimensions of 160 mm x 418 mm x 459 mm (WxDxH).
It lacks 5.25-inch drive bays, but has room for two each of 3.5-inch and 2.5-inch drives, a standard ATX PSU, and a ventilation system that includes two 120 mm front intakes, and two 120 mm rear exhausts. And yes, you can use them for two 240 x 120 mm radiators or AIO water coolers.
The second case today is the BitFenix Atlas, a cubic case that is designed to compete with the likes of Corsair Carbide Air 540. It measures 383 mm x 443 mm x 541 mm (WxHxD), and is compartmentalized, much like Corsair's case into two sections.
Its motherboard tray can seat E-ATX motherboards. There are no 5.25-inch drive bays, but a whopping ten 3.5-inch, and six 2.5-inch bays. Cooling system includes a staggering six 120 mm front intakes (can convert to four 140 mm), six 120 mm top exhausts (can convert to four 140 mm), a similar configuration at the bottom, and two 120 mm rear exhausts.
This part is simply speculation on my part, but it looks like both compartments can be switched around to suit users who like a right hand or left hand PC configurations, a nice new feature (if this is in fact the case).
Release dates and pricing remains unknown, but more information will be available in time.
Source - Techpowerup
The Atlas looks like they have taken a Corsair 540 and shrunk it.
Quite the opposite. Up to 4 x 360mm radiators is compatible with the Atlas. Oh, and the motherboard trays are removable and you can swap compartments for R-ATX on the right side of the case.
How did Bitfenix go from making elegant cases like the Phenom and Prodigy to... this Atlas? It literally looks like a plastic toy, some mix between an Aerocool and Thermaltake case :|
At least the Pandora looks slightly better, albeit a bit uninspired.
Edit; In the Atlas, at least split the HDD cages in 4 sections with 3 HDDs each. With the current config you can only use a slim rad with all HDDs, or a thick rad with no HDD's at all.
Have you see the Colossus?
There's aggressive styles, to calm and elegant styles. The design concept for Atlas was to bring up a new flagship to overtake the Colossus, and I do have to say it's still a lot less busier than Colossus.
Of course there are still lots to tweak on Atlas - LED's can be toned down, and the silver aluminum is currently hand made. The final version will be black so visual impressions now, please take them with a grain of salt if it doesn't look great now.
Here's a render we had on our wall:
https://www.dropbox.com/s/5ylzkkvd8ef1ymw/4.JPG
Alright, that's fair enough. Styling is always a personal thing though, I just don't happen to like 'agressive' 'gamer' cases :lol: I did find myself staring agressively at the logo that's not in the middle.
Gotta admit the black one looks a LOT better. Would imagine it'd look quite alright with white mesh. If that's easily removable, users can spray paint it in any colour they like *hint hint*
