Hi all! This is my first post here on your forum, though I've been lurking a while now.
INTRO
I'm fairly new to this whole overclocking business as I've recently built my first custom comp. I've hit an issue (not sure even it's an issue) that is getting a bit frustrating.
I've built my system around an i5-2500k, expecting to have a bit of OC'ing fun.
I've had it prime95-stable for 12 hours small FFT @4.6GHz /w 1.35V(bios) LLC1. I've since brought it down to 4GHz at the 1.25V the board gives as auto for stock clock, LLC off, and had it pass 24 hours prime95(FFT) and 100 runs in LinX. I havn't played any with the memory past setting it to the rated speed.
ISSUE
I seem to be getting a (un)fair amount of BSODs. My tweaks in the BIOS are incremental and i prime the new clocks/voltages for 2-3 hours before moving on to the next. The thing is, if I don't stop prime AT THE POINT OF FAILURE i get a BSOD and upon reboot i get a BIOS checksum error, another reboot leading to the BIOS recovering to the f2 BIOS.
Having the to flash the BIOS after near every prime-fail is starting to get to me.
Anyone got any insight to share with this p00r n00b?
SIDE NOTE
When trying to OC my GPU (ASUS HD6970), I get it furmark and Heaven stable (I think. I've done a lot more reading on CPU OC'ing) @950/1450 /w 1.175V, but when I reboot I get the BIOS checksum error mentioned above, with the following recovery malarky. I can't see what the BIOS and gfx card have to do with each other... Again, n00b :3
Thanks in advance!
INTRO
ISSUE
SIDE NOTE
Thanks in advance!
