BFG Tech?
Technex
Hi guys,
Trying to get a card RMA'ed from BFG, which apparently has a lifetime warranty.
Doing a bit of Googling as their site is down and it appears they are no longer in business?
So much for a lifetime warranty!!
Is this true?
Cheers,
Laurence
$hit... Not good! Dunno how they can advertise life time warranty then, bollocks lol...
Next best bet is the oven trick I hear? Maybe a hair dryer? Graphics card was giving strange lines all over screen (even in BIOS), and froze up after about 40 secs.
i dont try and fix hardware usually gets replaced but there are ppl on here that might notice this threat and help u, or look in the gpu part of OC3D im sure there's a baking guide
Cheers mate for your help I will have a look around
lol BFG have gone under all together - no more at all and it was the RMA's that killed them because Nvidia spent so long not getting Fermi right BFG had nothing new to sell to offset the cost.
TBH dude the lines across the screen means the ram is dead, if I was you even if you do bake it I would start saving as it wont work for long if at all now tbh
