Recommend me a USB wireless adapter for under £55
I've recently switched to Fibre and wanted to upgrade my USB adapter along with it. I've been searching for days on what the best USB adapter is but I'm still very confused. My router is a floor below me and with my current USB adapter, I only get 30mbps down and 10 up (the speeds I should be getting are more than double that) so I need an adapter with good range. I don't want a powerline adapter so I'd appreciate it if you didn't suggest one. I'll be shopping at Ebuyer.co.uk or Amazon and my budget it £50 though I can go higher if the performance increase is worth it.
Thanks guys.
EDIT: I'm looking at this one. what do you guys think?
Thanks guys.
