Best Kentsfield Board - Availble Now In UK!!
maverik-sg1
Asus P5W64-WS PRO 975x
A snip at only £200 but this is the board that will happily cope with Kentsfield cpu's and unleash its overclocking power.
Cheers
Mav
But if you dont want to upgrade from your P5B deluxe it will run a kentsfeield quite well too but no sli :O
I've been looking at one similar to that on XXXX the Asus P5WDG2 WS Pro. Would that be compatible with kentsfield aswell?
EDITED - no competitor sites here :)
name='Highland3r' said:
Can you not just run h4xed drivers?
When the PCI-E divides teh 2nd slot is only PCI-E x4 which means a performance hit so you are better off with a 7950GX2
I have heard that new revisions of this chipset (on ASUS) will have some sort of crossfire certification though ;)
Cheers
Mav
mav, any idea whats the differance between these 2 boards?
Asus P5W64-WS Pro Intel 975X (Socket LGA775) PCI-Express DDR2 Motherboard
Asus P5WDG2-WS Professional Intel 975X (Socket LGA775) PCI-Express DDR2 Motherboard
Cheers
Mav
Not chipset, It's the drivers.
The new 6.9 drivers enables crossfire support on 965 chipset mobo's :)
