tolagarf
Member
I got this EKWB FC-Titan X water block second hand for use with my GTX 1080 Ti, however I was having issues with the card only giving me a black screen, and in the device manager I would get the yellow triangle icon with an error code 43. Nothing I did would spring the card to life, so I took the block off it again and noticed something odd...
When the water block was installed, the PCI-e connector on the graphics card was slightly bent, so no wonder it's not working as the pins won't connect properly in the PCI-e port. I then took the block off the card and inspected it, and noticed both the copper block and acetal top was bent.
What in the world could do this? Should I even hope for some warranty on this, if one could claim it's a factory fault.
