Bench Team Chat.
Hehe
My sig says it all
Voltage - The cause and the solution to all our problems
Now you just need a single stage kompressor. Dice is to cold for most 2600K and 2500K cpu's. My old 2500K had a sweet spot around -40c to -60c with more cold it would just crap out and shut down.
But at Dice I don't blow my ear drums with the sound of the thing XD
Trying to set a voltage mark in my head looking at other peoples submissions, so that I don't get voltage hungry, and end up connecting the thing up to the national grid!
1.58-1.68 volts with cold.
You might have to give it more vcore then running on dice to keep the cpu from cold bugging.
Well happy, can hit 200-215MB/s on the XP startup in PCMark05 every run
5870 arrives Monday. Then I'm set for some PCMark fun finally after months & months of delays! Aiming for X1, X3, X4 & X6. Need a decent 775 setup for X2 which I don't have plus no LN2 for a good clocking E8XXX chip either.
Only issues I have - my Web page rendering is only 22 pages/s. No idea how to get 30+ like some others. Also my Transparent windows was only 10,000ish (W7 64-bit). Need 13,000+. Tried Server 2008 and it dropped to 7,000. Not figured server out yet. Not tried Vista yet either. Waiting for the 5870 to arrive before I tweak again. Have a feeling 3D Pixel shader is going to be an arse. GTX 580 could only master 2,500 fps. Need 4,000 with the 5870 to stand a chance.
God installing OS is boring.... doing all three at the same time, just to get the bloody thing over with!
I have to say this newly upaded Hwbot is quite interesting. I like how it rewards ever variation e.g 1x 2x 3x 4x gpu's instead of just the overall world records.
Doing some benches with my two new hd6950.
Edit: They do well in 3dmark03,3dmark vantage and unigine.
If i just could find me a 5.5ghz i7-2600k
Done a few runs of pcm05 in X6 class with this 3930K.
http://hwbot.org/submission/2225566_
Pretty sure I can hit 220 XP. Did it a few times before but I'm worn out. Tomorrow try again. Don't think I can get anymore out of certain areas due to clock speed. Can't run it any higher than 5G on the H100; either need a better chip or LN2 for a 990X lol. Would like to run @ 5.3+ but it's just too expensive to batch search SB-E chips. I reckon I can get 40K with this 2700K sitting here.
Tweaks wise, need to find out how some people get 30+ on web page rendering - haven't a clue how. Done all I can that I know of.
My P/3D & 2D G.Mem is lower than what it should be compared to other results @ same GPU clocks or lower. Something to do with 2D clocks not running at 3D clocks you think?
My HDD scores are lame but my acard was cancelled due to no stock :/ Using RAID 0 m4 64GB. Virus scan @ 560-630 depending on what stripe i choose; 32K being the best. HDD general usage is shite but nothing I can do without acard.
