alpenwasser
vvv HERE!!! vvv![]()
Yay!
Am I the only one that sees a face in this?
Now that you mention it... :lol:
Slowly falling in love with this...
Can't wait until you throw the hardware in!
It shouldnt be impossible to solder something together your self, if you have the gear for that?
From what your describing they are all running at the same speed, since there will only be one controlled connected to the mobo.
Just order some headers from electronics shop, solder them together, then put some isolation on them and put it behind the mobo-plate.
If you want you can even make a box to put it in.
Only issue is that you need to pull out the 5V to split into controls, so they dont run at 3rd times the speed, if you connect 3 fans![]()
This is an overview of the wireing.
Pretty straight forward
From this thread you do look like a guy that knows how to make a box to put it in.
You should be able to split almost indefinatly.
[...IMG...]
Sure thing.
Just something I got from googling your box + diagram![]()
Looks good so far, keep it up
Very, very tidy too!![]()
It looks much better now, imo!
The last picture background reminds of professional sound absorbing foam in studios up close for some reason
Nice work keep it up![]()
This just keeps getting better and better haha, great work mate
Love it!! And I'm a carbon fibre hater usually.![]()
