Asus Sabertooth 990FX NH-D14
blair
Hi,
Will the cpu cooler mentioned in the title fit on the motherboard mentioned in the titles without hitting the heat sinks?
give us something harder mate
was a simple check on Noctua's site
http://noctua.at/main.php?show=compatibility_gen&products_id=34&lng=en#AM3+_Asus
short answer is yes
Ah thanks
ok what 16 to the power of -1/2?
On a side note whats better for gaming a FX4100 or a 960T? at stock and max OC on air. also out of the two shopping lists below which is best.
4GB (2x2GB) Corsair DDR3 Vengeance Jet Black LP, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.5V
£22.08inc VAT
Noctua NH-D14 Dual Radiator and Fan Quiet CPU Cooler
£64.18inc VAT
HOT SELLER AMD Phenom II X4 960T Black Edition, S AM3, 3.0GHz, 8MB Cache, 95W, Retail
£95.95inc VAT
Asus Sabertooth 990FX, AMD 990FX, S AM3+, DDR3, SATA III - 6Gb/s, RAID SATA, PCIe 2.0 (x16), ATX
£121.19inc VAT
OR
£22.08inc VAT
HOT SELLER Gigabyte GA-Z68XP-UD3P, Intel Z68, S 1155, DDR3, SATA III - 6Gb/s, RAID SATA, PCIe 2.0 (x16), ATX
£126.82inc VAT
HOT SELLER Intel Core i5 2500K Unlocked, S1155, Sandy Bridge, Quad, 3.3GHz, HD3000 IGP 850Mhz, 6MB Cache, 95W OEM
£166.98inc VAT
Coolermaster Hyper 212 Quiet CPU Cooler 4 Heat Pipes 120mm Fan Intel S775/AM2/AM2+/AM3/754/939/940
£19.16inc VAT
Budget is really £300 which one is best overall in performance, quality and most reliable not just the most powerfull please
SB will beat the current AMD offerings IMHO all day long not sure how well the hyper 212 will do on it but its a decent budget cooler til ya can get a d-14 on it
Hi,
I have a 1100T @ 4 GHZ with the aforementioned board and cooler, works great for gaming! That being said you would be better off with an i3 2300 and eventually upgrading to ivy bridge or a faster SB if all you want to do is game. I run other highly threaded apps, and i did not want to splurge for a 2600k, although it would have been nice to have 8 threads.
