I'm not worried about it, but that is at stock so I'd be lying if I said I wasn't a little disappointed. Thanks for the sanity check though![]()
Well I've attached a quick screenie from hwinfo & cpu-z, the only things worrying me are the volts, is this normal?
Thanks for the info, just set it to 1.22 in the bios and although it's not made a massive difference to idle temps, it has brought load test temps down by 10/12 degs. What I find strange is that when I fire up prime95 the vcore drops from 1.208 to 1.76, ever heard of this happening?
(btw, I'm conscious of hijacking your thread, would you rather I make a new one?)
Yes, totally meant 1.176. I feel 1.76 would end expensively.....
Ah yes I have heard Tom talk about that before, and now I've come across it for myself. I'm with you on the 1.3, it does seem a little high for stock speeds especially when you managed to get to 4.6 on a very similar config (although it is within Intel's tolerance).
When you got yours running to 4.6 did you have to change much other than the vcore and the multiplier? This is my first chip coming from 775 so very new to it![]()
I just read through the whole of the build log. You can really see how it's came along over time! Amazing build!
