clone38
Heres is a mod that can be done to these waterblocks ive never liked the frosted look with the circles but now they don't look so bad.
All that you need is some 1500 wet and dry make sure you place the wet and dry on a flat surface I used the wifes chopping board as it was made of glass,then use some warm soapy water then place your hand flat over the block and go back and forth on the paper make sure you only go up and down,this only takes about 5 minutes per block once done then wash and dry them.
Last part use a soft cloth and some car polish I used Autosol did this about 4 times and then washed the blocks in warm soapy water dryed them off and buffed with a clean cloth,time to do this about 30 minutes the hard part was the seals man they where a pita.
