Asus 560ti Should i upgrade or no ?
Unless you notice you start to use more than 1gb video memory or use more than 1 monitor, or game higher than 1080p, or use a higher than 60hz monitor you shouldn't need to upgrade that 560ti. I would immagine the new cpu gave that 560ti a little boost as well.
If you spent all that cash upgrading everything, I would at least upgrade to the 660ti.
Either that or something better. I personally think that to get the 3570K and then not get a 6 series GPU is a bit of a waste.
Just my opinion, but the 560ti will still play most things fine on lower details
Not really. The 560 ti is a great card. I would recommend to wait till next year. Once the new amd or nvidia cards come out. the 560 ti can handle most games at 1080p at highish settings:D
Well, as stated earlier - upgrading all other components i´d personally also upgrade the GPU - the 560Ti is a good card, but there is no doubt u could do better for a reasonable cost if youre a avid gamer.
If youre good with the performance of the 560Ti you could always wait - but 7950´s are very good value right now and overclock like hell.
