Ok I was told that the Vapochill Sucked well I had one and I will tell you now that it is a whole lot better than people give it credit. To prove what I am saying I am providing links to reviews of the cooler. I havent come across a bad review of the cooler as of yet . Heres a few quotes from the reviews before I post the review links.
Heres the review links.
http://www.3dgameman.com/vr/asetek/vapochill_micro/video_review_03.html - 3dGameMan.com
http://www.tomshardware.com/2006/04/25/six_coolers_for_amd_processors/page23.html - TomsHardware.com
http://www.xtremecomputing.co.uk/review.php?id=219 - XtremeComputing
http://www.legitreviews.com/article/257/1/ - legit reviews
http://www.techpowerup.com/reviews/Asetek/VapochillMicro - Tech power up
http://www.madshrimps.be/?action=getarticle&articID=348 - Madshrimps
http://www.hothardware.com/Articles/Asetek_VapoChill_Micro/ - Hothardware
http://www.bytesizedreviews.com/index.php?rev_id=286&action=reviews&cat_id=68 - Byte Sized reviews
http://www.bcchardware.com/index.php?option=com_content&task=view&id=1856&Itemid=40 - BCCHardware.com
http://reviews.pimprig.com/cooling/asetek_vapochill_micro_cpu_coolers.php - PC Apex
http://www.hardware-review.net/html/modules.php?name=News&file=article&sid=902 - Hardware review .net
http://www.tweaktown.com/articles/897/ - TweakTown
http://www.bjorn3d.com/read.php?cID=831&pageID=1744 - Bjorn3d.com
I would recomend one of these coolers to anybody.
I know I will get some negative comments about this but thats life. I can get more Links but Im sure this is sufficient
I was a bit skeptical on how well Asetek could pull off the VapoChill Micro. Not only did this product perform very well, it did it in near silence when using the Ultra-Low Noise model. This cooler out performed the massive Thermaltake Big Typhoon and it did it without having to remove the motherboard. Asetek has been making a name for themselves with their extreme phase-change "VapoChill" systems, and now they continue the trend through their HSF's. Overall, I was blown away by the performance of this unit on a toasty Dual-Core processor. If you are running a single core Athlon 64 "Venice" core, you'll be able to overclock like a trooper - all without water. Very cool stuff.
So after all is said and done, what do I think of the Asetek Micro heatsink? I like it, I like it a lot. Although it doesn't blow my Zalman out of the water, it performs on par which is saying a lot. There is no need to pull your motherboard to install it and you have some options when it comes to fan type. My Zalman will stay off my testbench rig for now, the Micro has received the honor of performing cooling duties for it.
Asetek is to be commended for designing one of the most innovative and effective heatsinks that we've seen in the industry since the Zalman line was released. The large pipes, offset fan, and bottom chamber make for a product that will be hard to top. I already have ideas running through my head about how to cut a new shroud so I can run a 120mm, and design it so I get even more room between the fan and fins. Oh yeah, Asetek hit a home run with this line of heatsinks, the Big Dog recommends that you at least try one of these bad boys. I'm impressed, and that ain't an easy task to accomplish. Will I eat my words on the forum? Gladly. You can score one of these over at FrozenCPU for ~$52.99 - €44.30 ($59.99).
The VapoChill Micro Ultra Low Noise is a cheap but capable CPU cooler. By using a gas inside the heatsink, Asetek has managed to create a light but still very good cooler that easily can compete with larger, heavier coolers. Asetek also has managed to create a cooler that can be installed by most users, not only the hard core computer experts.
