Cragzman
Hallo fellow geeks.
While messing about with overclocking and benching (still a tad noobie), just for a laugh I ran Unigine Heaven 4 on on a loop with the following:
Phenom II 965 @ stock 1.325v LLC High (with an H100i)
HD7950 @ stock
GA-990FXA-UD3
Kingston Hyper-X 8GB DDR3 @ 1600MHz
CM Silent pro Gold 1200W (overkill I know)
With this, its runs as expected with no problems at all. But if i OC the CPU to... lets say 3.8GHz @ 1.350v LLC High, run Unigine Heaven 4 again on loop, after some time, the screen goes black, and the FPS counter in the top right corner reaches 200FPS+ and top menu remains.
Here is the best bit. When this happens, I envoke a force close of Heaven and then artifacts happen. Like if I open up IE10 or Firefox, some of the text within the window either has huge gaps or the text is absolutly huge. It changes when I scroll. A reboot of the machine seems to sort it.
What would be the first thing you would check? All the temps seem grand. CPU not going over 42c, and GPU operating well within safe limits.
Any ideas?
Cheers
HD7950 @ stock
GA-990FXA-UD3
Any ideas?
Cheers
