Are these settings oke ???
twister
Hello guys, I have a question about the settings I used for overclocking my i5 4670k.
First let me tell you my system specs.
I5 4670k
Asus sabertooth z87.
corsair h105 AIO
corsair dominator platinum 8gb 2133mhz c9.
be - quit darkpower pro 10/1000w.
Cooler master haf X.
I have not much experience with overclocking, so I would like to now if these settings are oke for a 4.5ghz overclock.
ratio 45
llc level 6
power phase control optimized.
cpu current capability 120%
internal pll overvoltage enabled
vcore bios 1.1980v
cpu input voltage 1.8v
cpu spread disabled
Eist and c-states enabled, Disabled during stress testing.
I did first a 10 run intelburn test at very high settings, did a couple of cpu benchmark and a few games, It did not give my any problems.
Then I did a 20 run itb.
No problem it can happen, but still I have no answer :), are those settings good for 4.5ghz
If thats what your cpu needs thats what your cpu needs. I think you need to post some CPU-Z's etc though and take a look at your Vcore under load to work out if thats the right LLC setting for you
I would have if it worked, It will not let me upload.
Dont upload pictures anyway. The site scales them down and it makes them look horrible. What youve done now with the IMG tags is the way to go :D
You need to screenshot when IBT or OCCT is running to see what the vcore in CPUZ says....
No point setting the LLC unless you NEED to touch it otherwise the vcore may be getting put up when under load....
Ive covered all of this in the guide.
