At 35db, i'd have to run that thing at 7, if not 5v.What you want to look at is static pressure. A good static pressure is around 3.0mm/H20.
Some of the best RAD fans I have found are these (http://www.corsair.c...-120mm-fan.html)
The NZXT Enthusiast range of fans is perfect for keeping your PC temperatures under control whilst maintaining near silence!
- Size: 140 x 140 x 25 mm
- Current: 0.13-0.55A
- Input: 1.56-6.6W
- Speed: 1000-2000RPM +/- 10%
- Air Flow: 49.1-98.3 CFM
- Air Pressure: 0.56-2.2 mm-H2O
- Noise: 22.1-37 dBA
- Bearing: Fluid Dynamic Bearing
- Life: 35,000 hrs
- Input: 1.56-6.6W
- Life: 35,000 hrs
Akasa AK-FN062 Apache Black Super Silent 140mm FanAkasa Apache's or Viper's would be a much better choice
Not as good as the Corsair's, and still too noisy for my liking. I think the NF-F12s are noisy, but these fans are in another league!
It is only 35DB at max speed. Chances are you will never use that, and chances are you don't have an overclock that will need a fan like this if you are striving for quiet (which in turns offers less performance). Clearly this fan is not for you then.
You either go quiet and sacrifice performance or you go loud and get a but load of performance (this is pretty much the law of PC fans).
noise is not a big issue for me a I have air cooled for a while and you get used the fan noise, I am running a Zalman CPN 9700 cpu cooler not the quietest in the world.It is only 35DB at max speed. Chances are you will never use that, and chances are you don't have an overclock that will need a fan like this if you are striving for quiet (which in turns offers less performance). Clearly this fan is not for you then.
I don't know if i'm having spectacularly bad luck when it comes to my fans, but all the Noctuas that I have seem to be too loud for my liking. I thought that spending £20 per fan would ensure that they'd still be quiet at 12v, but apparently I was mistaken![]()
I guess if you get a low FPI count rad, the Corsair's at 7v would be a good option. They're definitely better looking than the Noctuas.
You should go for a passive cooling configuration.
Or invest in earplugs![]()
