equk
I just bought this GPU cooler, mainly just to stop the noise from my x1900xt stock cooler seems to randomly put out
I tried installing it and 1st problem was the voltage reg HS doesn't fit as it's too big and components are in the way. So I thought "nvm I'll leave the stock one on".
Next problem came when I put the mem heatsinks on. The tape wasn't even sticky. I pushed them down firmly, but as soon as you turn the card over at least 2 of them fall off
Also to make matters worse the heatpipe touches the bottom RAM sink
not that I'd be happy to turn the pc on with the supplied RAMSinks
Anyway, I was wandering if anyone else has this cooler and if they have, whether they had any problems. Maybe I'm just unlucky or something
complete waste of £11 tho
