Very nice. Thanks a bunch. I could not figure out why my image never showed up on the Aquasuite upload. Now I have it working, thanks again.
Intriguing I might have to get me one of these. It's a shame there is no 6 LT with no display because I wouldn't mind running PWM fans again. How do the 5's handle normal 3-pin fans? Do they give you like an equivalent range of 7-12v. They are so confusing to read about it would be great to hear your thoughts. I would be looking to just run about 10-13 fans varying by CPU and GPU temperature. Thanks, if they can offer what i'm after i'd love to join the club and add another sexy post to your thread!
JR
I don't think the 5LT can run all those together. You can get a 6 and take the screen off and run it like an LT through the software. That could handle all the fans I think, and it would be cheaper than buying two 5LT models.
Another thing to note, if using PWM Corsair fans in a group, there is an issue when using splitter boxes. From what I am told, four PWM fans or more on some blocks are not controllable. Something about the fans and the PWM signal strength. I am only running three PWM Corsair fans per block, and don't have any trouble. I don't know what the non PWM fans will do because I have never tried them.
Any fan channel can deliver a current of 1.65A and the maximum combined current of all channels is 5A. Depending on the used heatsink the maximum power dissipation is dynamic limited.The maximum amount of fans to be hooked up on one unit is 8 isn't it? ... Will it properly handle 8 SP120s simultaneously?
Hopefully JR23 will step in to answer how he's set his up. It'll only work through the Aquaero 5 if it's just a single colour LED strip though, so if you have a RGB coloured LED strip, the recently released Farbwerk will be exactly what you're after.But how are the LED strips controlled with these? Are the attached to the white 4-pin connector and voltage adjusted like the fans are?
You have to be running the Aquaero 6 with PWM fans to do that (as per the demo vid earlier in the thread).Hang on a sec. I thought this was capable of handling 20fans per channel without a need of any cooling?
You might be in luck as the 6 XT does up the analogue wattage limit too, with a maximum current of 2.5A per output, for a total of 30W per channel at 12V.hmm, I have the aqua aero 6 XT and was hoping to run around 25 fans on it. These were non pwm fans though.
So if your fans are 0.4A each or less (at 12v), you should be able to run 6 per channel for a total of 24 fans.
As each SP120 draws 0.18A in use, you'll be safe to run 2per channel for a total of 8.
The limiting factor here won't be amperage, but heat generated by the fan amps when you run the fans slower than full speed. However 2 per channel is a comfortable limit for the Aquaero 5, so you're unlikely to run into problems doing that.
https://forum.aquacomputer.de/wasserk-hlung/107395-neu-aquasuite-2017-daten-ohne-grenzen/
They now are starting to charge a license fee for older hardware. I have mixed feelings about this.
