any mech/tyre fitters need help with bike
Rob_the_scot
As the title says is there any one who is a mechanic or a tyre fitter Specially when It comes to motorcycles?
Problem is I need need tryes, the manual I have is not 100% accurate and states the following
rear = 140/70 (17inch)
Front =140/80 (17 inch)
My bike when bought 2nd hand from a dealer came with the following
rear= same as above
Front= 110/70
Could I get away with buying 110/70 foe the front or buy what it says in the manual even thou the info in the manual is for a older bike that was recalled and the info isn't 100% accurate
My bike is known as a gilera sc 125 2008
also know as a derbi gpr 125 se racing (not nude, not 4 stroke or just gpr)
Standard front tire is a 110/70. The manual is a joke - it even claims a 57 tooth rear sprocket is fitted as standard.
I did notice that actually ny bike is 17-57 instead of the 16-57 I know there was a recall on the bike a few times
1. with battery not having enough cca
2. Frame needing replaced
