any info on PC-X2000F?
marick626
Anyone own or know of any issues with this case other than the size?
I really like this case and think it would be great but I don't know where to buy it or if there are any problems with it.
I also can't find any info on cable length requirements, specifically sata data and power.
I am in the U.S. btw.
I have the PC-X2000 ( not F version ) what exactly are your concerns?
Well in the F version, the PSU is on the absolute bottom unlike your version which is right next to the cd drives. I just wanted to know if I needed longer Sata data and power cables for the case since it is rather tall and don't think regular cables would reach the cd drives.
yes use the 1 metre cables and you will need an psu extension as well for the mobo.
I had the psu in the bottom when i had mine under water and needed the longer cables.
The case comes with several extra-long SATA cables, so you're covered there. I'm using it with a Corsair AX850 PSU which also has longer-than-usual cables; no issues re cable length.
Only problem of note was installing the Blu-ray burner (Pioneer BDR-205)...due to the size of the drive, was unable to re-insert the aluminium placeholder at the rear of the drive while the push-button bezel was installed at the front, so have shifted the drive forward and left the bezel off. The bezels are reported by some sources to be easily broken; having had a couple of similar (identical?) ones fall apart in the past, I can believe it.
