AMD Ryzen 1950X Threadripper Retail Retest
I was building a system for a friend he does a lot of video work , rendering and things like that it was an 1950x AMD threadRipper it is a monster but he was looking to overclock it is a full water cooling system and can get 3.8 across all cores with 3200 RAM speed it make an absolute god awful amount of heat , it is the first time I ever had the worry about the motherboard socket getting too warm it is actually ridiculously warm to the touch and to be perfectly honest even running system like this long term I honestly have no idea what it's going to do to the motherboard the heat it is putting out it's just crazy I did understand going into list that the heat would be a problem but it took me by surprise big time
maybe an air cooler that cools more of the surrounding socket is a better choice.
i am not a big watercooling fan to be honest.
if i have the choice i go with air cooling every day.
noise at idle and reliability (as experienced by friends) kept me away from watercooling.
noctuas nh-d15 has given me no reason to buy into watercooling in the past.
I've ordered an 1950x, Zenith Extreme and an EK threadripper.
When they are delivered I can test them.
I'm guessing I shouldn't have issues cooling it as I've 3 60mm thick rads 1 480mm and 2 360mm rads so I will try for a decent overclock and report back.
I am hoping to use this to replace my Ryzen 1800x rig and 5820k rig as should have more cores than both together :).
If its just the cpu after one rad it wont make a great deal of difference
One rad is not enough, especially for a dual GPU system. Don't know why you keeping banging that drum Tom. I love ya guv, but you're so wrong on that one. Multiple rads makes a HUGE difference to liquid temps.
Multiple yes - but not that many!
I used to run a pair of GPU's, cpu and board on one thick and one thin 360 with the fans at a constant 500rpm
Were you aware of your liquid temps? With my previous rig (x79 / dual 980s), 2 rads is nowhere near enough. I have a slim 420 and a slim 360 in that rig, and liquid temps are still too warm for my liking unless I crank up the fans. Rad space counts.
Liquid no (sensors mean clutter) but the CPU max was 70 and the GPU's never saw 50
Damn, those numbers are far too warm for my liking, personal preference and all that. I imagine Threadripper will be far worse too, considering the heat output if OCed. I wouldn't go less than 3 GOOD rads for a TR rig with dual GPUs. If it were my rig, it would be five! 16 overclocked cores is mighty toasty.
Air cooler can keep TR to 70's
I built mine to be uttery silent (and it was) despite running on the ragged edge
Orca was in use daily for 4 years and never skipped a beat
CPU's are never 'cool' no matter what youre cooling them with if youre runninng a huge amount of volts. Ive tried multi rads in the past - lets face it Ive got most kit just available here to grab for reviews. Not really a massive point in it.
Stock or OCed though? I'm hearing TR is tough to keep cool when OCed (as expected, it's 16 freaking cores). Rad overkill sounds justified in this case.
P.S. there's no massive point in anything we nerds do Tom. :) I just enjoy seeing a pair of 1080TI's OCed to 2075 / 6005 top out at 37C under full load. Rad overkill is my thing, silence is yours. I just think that rad overkill is a good thing in this TR case, especially for OCers. I'm sure it's fine stock, just like my Ryzen is, but we're not hanging out at OC3D because we like stock now are we. ;)
Still dont need that many rads dude. If its filling the case fine but just make sure its tidy and the hose is kept very clean
I've had the rads in this case for a while now, I built it to be a case that lasts a few systems.
Its a little devil V10 case so if you didn't have 3 big rads in it, it would look empty.
It is extremely tidy for a big case. (Well since I switched over to Threadripper last night in a hurry, tubing/cabling needs a small bit of work). My 1080's are on order so until then I just put the system together quickly.
I set up the 1950x last night and switched over from a 5820k, I thought I could get away with it for a night without reinstalling (After loads of headaches/micro stutters in games) I finally wiped the OS. I had 5 mates over for a gaming night so didn't want to have to wipe in the middle of a gaming night.
A couple of issues I found was horrible stability and the cpu was idling at 65 and going up to 75 degree's. I was thinking did I mess up the block mount. (checked with a thermal probe and showed fine).
Turns out their is a bug in the original bios and when I updated to the latest bios the system showed 25-35 idle and 45 under load and all the stability issues where resolved.
The little fan is like a jet engine and was constantly on with the bios bug, its now permanently off since the update.
Mike Irish & AMD 1950X
I have the ASUS X99II Deluxe and the intel 6850K and have had nothing bet problems. I have changed out the bard and CPU twice and still the same. I am now running it at 37 Ghz on all cores. I also have eight 8Gb sticks of G Skills trident Z memory and cannot get it to run any more that 2800:confused:! I use Lightroom Photoshop and some other photo processing programs. I have found that lightroom is very memory intensive.
I am now thinking to move over to AMD Tread ripper 1950x. Sorry I forgot to mention that I am using the Corsair H 100 280mm cooler. I was also thinking of using the ASUS ROG ZENITH EXTREME X399 Gaming Motherboard with it. Could you please give me your feeling on thes please.
Mike
