Hi All,
I have had some recent success on overclocking my system and thought that my experiences may help others.
System:
AMD Phenom II 3.2GHz x555 black edition CPU (Dual core)
Gigabyte GA-890GPA-UD3H
8GB DDR1333 RAM (AData)
Sapphire HD5770
Enermax Liberty II 620W PS
CoolerMaster V8 cooler
WD 1TB Black Edition HDD
Windows 7 64 bit
I have successfully ran the PC in quad core unlocked mode @ 3.4GHz on the stock AMD cooler but was concerned about the higher temps so ended up getting the V8 cooler...which of course leads to more tweaks to squeeze the max out of the setup
The long and the short of many hours of fiddling has resulted in a rock solid setup with the following settings:
Quad cores unlocked
CPU Ratio x19.0 (3.8GHz)
CPU voltage 1.350v
NB ratio x12 (2.4GHz)
HT ratio x12 (2.4GHz)
NB voltage 1.340v
This resulted in a CPU temp via ET6 of 55 deg C (running Prime95). A trick that caught me out for a while was once you unlock the 2 other cores, the core temps no longer show up in any of the apps I have tried so far including AMD's OverDrive.
Another trap is that the ET6 application displays the correct CPU voltage but AMD OverDrive assumes it is still at 1.3v so if you have made all the settings via the BIOS, be warned that AMD OverDrive will not necessarily tell you the full story and any further changes by the AMD OverDrive app will show any changes but be out by the delta between the BIOS set voltage and 1.3v.
I have tried going to 4GHz but at 3.9GHz Prime95 starts to show errors even with the CPU voltage stepped up to 1.400v so have settled on a good compromise between added performance and stability.
Here are the benchmarks between the original factory default settings and the overclocked settings:
The above shows a healthy improvement and good bang-per-bucks for this CPU and if you are looking for an entry level processor with some good gains, then the x555 black edition is a good bet.
(PS. As a newbie, I may have posted this in the wrong area so please let me know if that's the case)
System:
Sapphire HD5770
Windows 7 64 bit
Quad cores unlocked
CPU voltage 1.350v
NB voltage 1.340v
Code:
Setup Units Stock Overclocked
Cores 2 4 100%
Core Frequency GHz 3.2 3.8 19%
HT/NB Frequency GHz 2 2.4 20%
Core Voltage Volts 1.3 1.35 4%
HT Voltage Volts 1.3 1.34 3%
Graphics Card
GPU Clock MHz 850 925 9%
Memory Clock MHz 1200 1350 13%
PC Mark
PCMarkSuite 4992 7851 57%
Memories Suite 4750 6555 38%
TV and Movies Suite 3200 4981 56%
Gaming Suite 5488 8117 48%
Music Suite 5764 5686 -1%
Communications Suite 5369 8410 57%
Productivity Suite 4582 7529 64%
HDD Test Suite 4490 4764 6%
3D Mark
3D Mark Score P7667 P11046
GPU Score 9644 10553 9%
CPU Score 4747 12844 171%
GPU Test 1 FPS 29.77 32.82 10%
GPU Test 2 FPS 26.68 28.94 8%
CPU Test 1 Plans/s 606.69 1650.15 172%
CPU Test 2 Steps/s 7.55 20.22 168%
Feature Test 1 Gtexels/s 31.57 34.34 9%
Feature Test 2 Gpixels/s 3.84 4.29 12%
Feature Test 3 FPS 30.59 33.38 9%
Feature Test 4 FPS 28.74 31.08 8%
Feature Test 5 FPS 33.87 39.24 16%
Feature Test 6 FPS 86.36 93.92 9%
NovaBench
Overall Score 845 1141 35%
System Ram 153 157 3%
CPU Tests 251 479 91%
Graphics Tests 421 484 15%
Hardware Tests 20 21 5%
