amd 64 754 mobo info req.
pobolycwm
what is the best mobo for oc`ing an amd 64 3000 cpu any ideas or opinions
what is the dfi lanparty board like need summat that is overclockable rather than the poxy asus board i got (k8v se deluxe)
thanx
jamie
Go for the DFI NF3 board, but get yourself a backup bios chip. They are just as bad as the DFI NF2 boards for the bios b0rking problems, but when they run, they are the best out there IMO
They are called BIOS saviours normally. They basically plug into the BIOS socket, the BIOS chip then sits in that and you copy your original BIOS to the saviour. Saying everything goes belly up and your BIOS goes down, flip a switch on the back and hey presto the saviour is used as the BIOS, then from that you can reflash your original BIOS, filp switch again and your back on the original BIOS.
A very complicated way of explaining such a simple thing lol.
Boardy
