Squidlorock
Hey
c3d:!:hello:
I've only just joined! Currently I have an age old rig (socket 775) and It has been not great recently... Currently I'm typing with on screen keyboard! And It's painful! Suffice to say my build has had to have been brought forward...:headscratch:
So after much reading for a long while I think Amd Is the only way I can go. With my budget quite tight (£500-550) and needing an os,aswell as a case I've been racking my brains.:freak:
Ok for now, I have an old ati/amd 5750, I will most prob have to use this in my build until I can get a gpu further down the line (6 months or so) Also, any thoughts are appreciated! Currently this Is what I've been looking at...
Asus M5A97 EVO R2.0
AMD FX8320 (or AMD6300)
Kingston HyperX DDR3 1600MHz CL9 8GB
Western Digital Caviar Blue 500GB SATAIII
Seasonic S12II-520 520W
Microsoft Windows 7 Home Premium with Service Pack 1, 64-bit
And for a case I had my heart set on an R4... but I was looking at the Arc midi v2 aswell, and the 300r (would want to go fractal really). But It's all about cost at the minute.
I would be running at stock, until I can get a hyper 212 evo, then Oc later on (If I can).
Some questions though...
Will the Seasonic be able to cope with an Oc'ed 8320 or 6300?(Some people have said It would be fine, with the quality of it... I was worried If It would be on the border)
Would It be better for the 8320 (read some, that the 8320 would be better for future games) Rather tan the 6300?(although that Is pushing my budget)
I really can't afford a gpu aswell currently, what are you're thoughts?
I had pretty much decided on Win7... but would Win8 be better now with 8.1 (dislike the sound of 8, with apps, cloud etc...)
This would be for me gaming/music/browsing, but probably cubase/fractal programs too...
Would the 8320 run ok with the stock cooler, at stock speeds until I can afford a cooler? Also, can the Asus M5A97 EVO R2.0 handle a decent Oc with the 8320/6300(had read it should be ok?)
I would have to use the 2 stock fans on the case for now...would that be enough?(will upgrade)
Sorry for the long post... just trying to make sure I have a solid build before I purchase...
And lastly I was even looking at FM2 and + with regards to the AMD Athlon X4 760k (would this compare to those cpu's...but a newer FM2+ board?) It might allow me a gpu, but at a cost.
This will be the First pc I actually built... (friends helped other older builds) So I'm excited but also nervous:crazy::blink:
Any thought/advice would be great! Sorry for the huge post and Thanks again.
Asus M5A97 EVO R2.0
