Aging GTX 460
Will do, i'm working on it XD maybe you could join?
I have 5870s with no voltage control
Hi guys im having the same issue. I have a Gigabyte 460 Rev 1 and a friend of mine wants it, so im planning to sell it and get the 560ti, will it be wort it? I cant afford 2 460 like you reccomend, but maybe i can stay with my old 460. I always play on 1920x1080 and I wont change it in less than 2-3 years.
Thanks again!
Hi guys im having the same issue. I have a Gigabyte 460 Rev 1 and a friend of mine wants it, so im planning to sell it and get the 560ti, will it be worth it? I cant afford 2 460 like you recommend, but maybe i can stay with my old 460. I always play on 1920x1080 and I wont change it in less than 2-3 years.
Thanks again!
It will be worth it if you are only planning on using 1 card, although the performance gain is small from a decent 460 1gb. It depends on how much your friend is willing to pay...
I would swap mine for 2x 560ti 448 editions if I knew they would manage better overclocks at lower temps. But i doubt I could get one to 1GHz like my 460, which is why I can play any game on full.
Heh, well just one card...Ill save 2/3 of the cost, thats why I accepted inmediatly but after reading a couple of articles I wasnt sure of doing it.
Thanks!
