Hello people just after some advice as if there is another better option out there.
as of late (a year or two) i have been busy with work so not been able to spend so much time playing games and using the computer but my old GPU has just started playing up. I dont think its an issue with the card its self but more of a driver issue which ive had quite a bit since i had it but instead of messing around keep installing the drivers again i feel the need to upgrade it so i can play some more up to date games like GTA, dirt rally etc etc
at the moment i have an old AMD HD6850 which was ment to be a stop gap between getting something better so im quite happy with the length of time it has worked for.
at the moment i play Farming Simulator 15 with my brothers little boy and that mainly it due to the limits with the card and a limited amount of time to play. also using a 1920 x 1080P res
other hardware at the moment is
Motherboard: - Gigabyte Z68X-UD5-B3
CPU: - Intel Core i5 2500K
SSD: - 120gb Kingston Hyper X
PSU:- 600 watt Corsair RM
